Configure metrics to control the use of routes in a routing domain.
Enable OSPF globally.
Ensure that the port uses an IP address.
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
 - Select OSPF.
 - Select the Stub Area Metrics tab.
 - Double-click the metric value to specify a new metric speed for the required stub areas.
 - Select Apply.
Stub Area Metrics Field Descriptions
Use the data in the following table to use the Stub Area Metrics tab.
                                 Name  |
                                 Description  |
                                 AreaId  |
                                 Specifies the 32-bit identifier for the stub area.  |
                                 TOS  |
                                 Specifies the type of service associated with the metric.  |
                                 Metric  |
                                 Specifies the metric value applied at the indicated type of service. By default, the value equals the lowest metric value at the type of service among the interfaces to other areas.  |
                                 Status  |
                                 Specifies the status of the stub area. This variable is read-only.  |
