Configure a specific advertising Backbone Edge Bridge (BEB) with a specific I-SID to apply the IS-IS accept policy to routes for a specific advertising BEB.
If the route policy changes, you must re-apply the IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map to apply.
 - Select IS-IS.
 - Select the Accept Nick-Name Isid tab.
 - Select Insert.
 - In the AdvertisingRtr field, specify the SPBM nickname.
 - In the Isid field, specify an I-SID number.
 - Select enable in the Enable check box to enable the filter.
 - In the PolicyName field, specify the route-map name.
 - Select Insert.
Accept Nick-Name Isid Field Descriptions
Use the data in the following table to configure the Accept Nick-Name Isid tab.
 Name  |
 Description  |
 AdvertisingRtr  |
 Specifies the SPBM nickname to allow you to apply the IS-IS accept policy to routes for a specific advertising BEB. The value is 2.5 bytes in the format <x.xx.xx>.  |
 Isid  |
 Specifies an I-SID used to filter. The value 0 is used for the Global Router.  |
 Enable  |
 Enables or disables the I-SID entry. The default is disabled.  |
 PolicyName  |
 Specifies the route policy name. You must configure a policy earlier in a separate procedure.  |
 BackBonePolicyName  |
 Specifies the backbone route policy name. You must configure a policy earlier in a separate procedure.  |
