Use this procedure to globally enable Application Telemetry so it can send packets to an Analytics Engine. By default, Application Telemetry is globally disabled.
You must complete the following:
Configure an agent IP address.
Enable sFlow.
Configure Collector 1.
 - Select Application Telemetry.
 - Select the Globals tab.
 - Select AdminEnable.
 - Select Apply.
Use the data in the following table to use the Globals tab.
 Name  |
 Description  |
 AdminEnable  |
 Shows whether Application Telemetry is enabled. By default, the check box is not enabled.  |
 ClearCounterStats  |
 Clears the Application Telemetry status counters.  |
