You can establish a threshold rate for receiving TC/TCN packets by configuring values for count and interval. If the threshold rate is exceeded, you receive a warning message.
Use the following procedure to configure values for tc-receive-alarm-threshold count and tc-receive-alarm-threshold interval.
Configure count and interval values:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#spanning-tree tc-receive-alarm-threshold count 3 Switch:1(config)#spanning-tree tc-receive-alarm-threshold interval 2
Display the alarm threshold configuration:
Switch:1#show spanning-tree tc-receive-alarm-threshold
             Spanning Tree TC/TCN Rx Alarm Threshold Configuration
Interval                : 2 minutes
Count                   : 3
Variable definitions
Use the data in the following table to use the tc-receive-alarm-threshold command.
 Variable  |
 Value  |
 count <1-1000>  |
 Specifies the number of packets used to establish the threshold rate. The default is 2.  |
 interval <1-15>  |
 Specifies the time interval (in minutes) used to establish the threshold rate. The default is 1.  |
