Use the following procedure to automatically reactivate the port
that is shut down by the SLPP.
                                In the Device
                                        Physical View tab, select the port.
                In the navigation pane, expand
                                Select
                                                General.
                                Select the
                                                CP
                                                Limit tab.
                                Select
                                                AutoRecoverPort to activate auto
                                        recovery of the port from the action taken by SLPP shutdown
                                        features.
The default value is disabled.
                                Select
                                                Apply.
