Clear the NEAP Session
Use this procedure to clear the NEAP session that is learned on the switch.
Clear a non-EAP client session by MAC address:
Switch:1> enable Switch:1#clear eapol non-eap 00:1b:63:84:45:e6
Clear a non-EAP client session by port:
Switch:1> enable Switch:1#clear eapol non-eap 1/16 00:1b:63:84:45:e6
The following table defines parameters for the clear eapol non-eap command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Specifies the port list on which the NEAP MAC is learnt. |
0x00:0x00:0x00:0x00:0x00:0x00 |
Specifies the MAC-Address on the NEAP session. |
