Perform this procedure to view location information of remote LLDP-MED on specific ports.
 - Select Port MED.
 - Select the Neighbor Location tab.
Neighbor Location Field Descriptions
Use the data in the following table to use the Neighbor Location tab.
 Name  |
 Description  |
 TimeMark  |
 Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021.  |
 LocalPortNum  |
 Specifies the port on which the remote LLDP-MED information is received.  |
 Index  |
 Specifies the particular connection instance that is unique to the remote LLDP-MED.  |
 LocationSubType  |
 Specifies the subtype of the remote LLDP-MED location:
 LocationInfo  |
 Specifies the location information of the remote LLDP-MED.  |
