You must disable the virtual service before you uninstall it.
Perform this procedure to uninstall a configured virtual service.
If a virtual machine is running, it is stopped, and then the service directory is uninstalled.
This command also works in Global Configuration mode but does not display if you use the question mark (?) help in that mode.
Switch:1>enable Switch:1#virtual-service tpvm uninstall
Use data in the following table to use the virtual-service command.
                             Variable  |
                             Value  |
                             WORD<1-128>  |
                             Specifies the virtual service name.  |
                             uninstall  |
                             Uninstalls the specified virtual service name.  |
