Configure redistribution of direct or static routes into the DvR domain, on the Global Router or for a specific VRF instance.
Configure route redistribution of direct and static routes on the Global Router. Ensure that you apply the configuration.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#dvr redistribute static Switch:1(config)#dvr redistribute static metric 200 Switch:1(config)#dvr redistribute static enable Switch:1(config)#dvr apply redistribute static
Switch:1(config)#dvr redistribute direct Switch:1(config)#dvr redistribute direct metric 100 Switch:1(config)#dvr redistribute direct enable Switch:1(config)#dvr apply redistribute direct
Verify configuration on the Global Router:
Switch:1(config)#show dvr redistribute
                    DVR Redistribute List - GlobalRouter
SOURCE MET MTYPE      ENABLE RPOLICY
STAT   200 External   TRUE  -
LOC    100 Internal   TRUE  -
                                                  Configure redistribution of direct and static routes on the specific VRF instance vrf1. Ensure that you apply the configuration.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#router vrf vrf1 Switch:1(router-vrf)#dvr redistribute static Switch:1(router-vrf)#dvr redistribute static metric 20000 Switch:1(router-vrf)#dvr redistribute static enable Switch:1(router-vrf)#exit Switch:1(config)#dvr apply redistribute static Switch:1(router-vrf)#dvr redistribute direct Switch:1(router-vrf)#dvr redistribute direct metric 10000 Switch:1(router-vrf)#dvr redistribute direct enable Switch:1(router-vrf)#exit Switch:1(config)#dvr apply redistribute static
Verify configuration on vrf1:
Switch:1(router-vrf)#show dvr redistribute vrf vrf1
                  DVR Redistribute List - VRF vrf1
STAT   20000 External   TRUE  -
LOC    10000 Internal   TRUE  -
                  Variable definitions
Use the data in the following table to use the dvr redistribute direct or the dvr redistribute static commands.
 Variable  |
 Value  |
 enable  |
 Enables DvR route redistribution on the VRF instance. Route redistribution is enabled by default.  |
 metric <0-65535>  |
 Specifies the DvR route redistribution metric.  |
 route-map WORD<1-64>  |
 Specifies the route policy for DvR route redistribution.  |
Use the data in the following table to use the show dvr redistribute command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies the VRF name.  |
