View IP VRRPv3 Statistics
Use the following procedure to view IPv6 VRRPv3 statistics for monitoring the network performance.
 - Select VRRP.
 - Select the V3 Stats tab.
V3 Stats Field Descriptions
Use the data in the following table to interpret the V3 Stats tab.
 Name  |
 Description  |
 InetAddrType  |
 Shows that the address type of the statistical entry is IPv4.  |
 ChecksumErrors  |
 Specifies the total number of VRRP packets received with an invalid VRRP checksum value.  |
 VersionErrors  |
 Specifies the total number of VRRP packets received with an unknown or unsupported version number.  |
 VrIdErrors  |
 Specifies the total number of VRRP packets received with an invalid VRID for the virtual router.  |
