Shortest Path Bridging MAC (SPBM) supports Layer 2 Virtual Service Network (VSN) functionality where Switched UNIs are bridged over the SPBM core infrastructure.
EAP and FA can coexist on the same port. EAP and FA can be enabled in any order; however, EAP must have Flex UNI enabled in order to function on an FA-enabled port. If EAP is currently enabled, FA can only be enabled if the port is a Flex UNI-enabled port.
You must configure the required SPBM and IS-IS infrastructure.
To configure a Switched UNI on a port, you must create a Switched UNI I-SID, and map the port to the Switched UNI I-SID.
When you configure Switched UNI, Spanning tree is disabled on all the Switched UNI ports.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/1,1/2 Switch:1(config-if)#flex-uni enable Switch:1(config-if)#i-sid 100 Switch:1(elan:100)#c-vid 10 port 1/1,1/2 Switch:1(elan:100)#untagged—traffic port 1/1,1/2 bpdu enable
Switch:1#show interface gigabitEthernet i-sid ======================================================================================= PORT Isid Info ======================================================================================= ISID ISID ISID MAC PORTNUM IFINDEX ID VLANID C-VID TYPE ORIGIN NAME BPDU SUNI ---------------------------------------------------------------------------------------- 1/1 192 27 N/A 4000 ELAN C --- - --- - ISID-27 FALSE 1/1 192 270 N/A 4001 ELAN C --- - --- - ISID-270 FALSE 1/1 192 309 N/A 309 ELAN C --- - --- - ISID-309 FALSE 1/1 192 401 N/A 401 ELAN C --- - --- - ISID-401 FALSE 1/1 192 1001 N/A 1001 ELAN C --- - --- - ISID-1001 FALSE 1/1 192 1111 N/A 1111 ELAN C --- - --- - ISID-1111 FALSE 1/1 192 1121 N/A 1121 ELAN C --- - --- - ISID-1121 FALSE 1/1 192 1201 N/A 1201 ELAN C --- - --- - ISID-1201 FALSE 1/1 192 2001 N/A 2001 ELAN C --- - --- - ISID-2001 FALSE 1/2 193 38 N/A 4000 ELAN C --- - --- - ISID-38 FALSE 1/2 193 310 N/A 310 ELAN C --- - --- - ISID-310 FALSE 1/2 193 380 N/A 4001 ELAN C --- - --- - ISID-380 FALSE 1/2 193 402 N/A 402 ELAN C --- - --- - ISID-402 FALSE 13 out of 152 Total Num of i-sid endpoints displayed ORIGIN Legend: C: manually configured; D: discovered by FA or EPT M: FA management; E: discovered by EAP; A: auto-sense l: discover by local switch r: discover by remote VIST switch
Variable definitions
The following table defines parameters for the i-sid command to configure a Switched UNI.
Variable |
Value |
i-sid <1–16777215> |
Specifies the service interface identifier (I-SID). |
c-vid <1-4094> |
Specifies the customer VLAN ID. |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Specifies the ports associated with the Switched UNI I-SID. |
bdpu enable |
Enables bridge packet data units (BPDU) for an untagged end point. |
