Determine the database used by the SPBM multicast module.
 - Select SPBM.
 - Select the IpMcastRoutes tab.
IpMcastRoutes Field Descriptions
Use the data in the following table to use the IpMcastRoutes tab.
 Name  |
 Description  |
 VsnIsid  |
 Specifies the VSN I-SID. Layer 2 VSN and Layer 3 VSN each require a VSN I-SID.  |
 Group  |
 Specifies the group IP address for the IP Multicast over Fabric Connect route.  |
 Source  |
 Specifies the IP address where the IP Multicast over Fabric Connect route originated.  |
 NickName  |
 Specifies the nickname used to filter criteria.  |
 SourceBeb  |
 Specifies the source BEB for the IP multicast route.  |
 VlanID  |
 Specifies the ID for the C-VLAN.  |
 VrfName  |
 Specifies the VRF name.  |
 DataIsid  |
 Specifies the data I-SID for the IP Multicast over Fabric Connect route. A a BEB receives IP multicast data from a sender, a BEB allocates a data I-SID in the range of 16,000,000 to 16,512,000 for the stream. The stream is identified by the source IP address, group IP address, and the local VLAN the stream is received on. The data I-SID is a child of the scope or VSN I-SID.  |
 Type  |
 Specifies the type for the IP Multicast over Fabric Connect route.  |
 Bvlan  |
 Specifies the B-VLAN for the IP Multicast over Fabric Connect route.  |
 NniInterfaces  |
 Specifies the network-to-network interface (NNI) ports for the IP multicast route. SPBM runs in the core on the ports that connect to the core. These ports are NNI ports. Ports that face a customer VLAN are user-to-network interface (UNI) ports.  |
