Use this procedure to view the QoS ingress port-rate limit information. The system displays the port, rate limit in Kbps, and rate limit status.
This procedure applies to VSP 4900 Series only.
Switch:1# show qos rate-limiting interface gigabitEthernet 1/1
Port Ingress Rate-Limiting
PORT RATE(kbps) ENABLED/DISABLED
1/1 0 DISABLED
Variable definitions
Use the data in the following table to use the show qos rate—limiting interface gigabitEthernet command.
Variable |
Value |
port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
