Display individual RMON statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View RMON statistics:
Switch:1>enable Switch:1#show interfaces gigabitEthernet statistics rmon 1/13 ================================================================================ Port Stats Rmon ================================================================================ PORT OCTETS PKTS MULTI BROAD CRC UNDER OVER FRAG COLLI NUM CAST CAST ALLIGN SIZE SIZE MENT SION -------------------------------------------------------------------------------- 1/13 1943 21 8 13 0 0 0 0 0
Use the data in the following table to use the show interfaces GigabitEthernet statistics rmon command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
