Configure a protocol ACE
Configure a protocol ACE to filter on the source port, destination port, ICMP and ICMPv6 message type, or TCP flags.
![Note](images/note.png)
For IPv6 filters, you must configure next header to configure the protocol attributes.
The ACL exists.
The ACE exists.
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
Specify ICMP packets:
Switch:1(config)#filter acl ace protocol 1 12 icmpv6-msg-type eq echoRequest
32 (decimal) |
16 (decimal |
8 (decimal) |
4 (decimal) |
2 (decimal) |
1 (decimal) |
Urgent |
Ack |
Push |
Reset |
Syn |
Fin |
Configure an ACE for TCP flags attributes: Example 1
The mask is set for an ‘ack‘ tcp flag bit regardless of whether any other tcp flag bits are also set:
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask ack ? <0-0x3F | 0-63> Mask value <Hex | Decimal>: This six bit mask is a reverse mask where 0:care about, 1:do not care about
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask ack 0x2f Hex Value 20 10 8 4 2 1 TCP Flags _ ack _ _ _ _ Binary Value 1 0 1 1 1 1 or in hex = 0x2F
Configure an ACE for TCP flags attributes: Example 2
A packet will match this filter if the 3 tcpflag bits are set in the tcp header (and only those 3 bits).
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags eq ? WORD<1-50> Tcp flags {none | fin | syn | rst | push | ack | urg | undefined} Switch:1(config)#filter acl ace protocol 1 1 tcp-flags eq syn,push,urg
You can configure a functionally equivalent filter with the mask operator as follows:
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask syn,push,urg 0x0
Configure an ACE for TCP flags attributes: Example 3
The mask operator provides more flexibility. For example a packet will match the following filter if the 'syn,push,urg' tcpflag bits are set, regardless of whether any other tcpflag bits are also set:
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask syn,push,urg ? <0-0x3F | 0-63> Mask value <Hex | Decimal>: This six bit mask is a reverse mask where 0:care about, 1:do not care about
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask syn,push,urg 0x15
Configure an ACE for ICMP message type: Example 4
filter acl 1 type inPort name "ICMP_TRAFFIC_FILTER" filter acl port 1 1/3 filter acl ace 1 1 filter acl ace action 1 1 deny count filter acl ace ethernet 1 1 ether-type eq ip filter acl ace ip 1 1 src-ip mask 194.183.100.64 0.0.0.15 filter acl ace ip 1 1 dst-ip eq 146.97.137.42 filter acl ace ip 1 1 ip-protocol-type eq icmp filter acl ace protocol 1 1 icmp-msg-type eq echo-request filter acl ace 1 1 enable filter acl ace 1 2 filter acl ace action 1 2 deny count filter acl ace ethernet 1 2 ether-type eq ip filter acl ace ip 1 2 src-ip mask 194.183.100.64 0.0.0.15 filter acl ace ip 1 2 dst-ip eq 146.97.137.42 filter acl ace ip 1 2 ip-protocol-type eq icmp filter acl ace protocol 1 2 icmp-msg-type eq echoreply filter acl ace 1 2 enable
Use the data in the following table to use the filter acl ace protocol command.
Variable |
Value |
{0-0x3F} |
Specifies the mask value. |
<1-2000> |
Specifies the ACE ID. |
<1-2048> |
Specifies the ACL ID. |
WORD<1–50> |
Specifies one or more TCP flags—none, fin (finish connection), syn (synchronize), rst (reset connection), push, ack (acknowledge), urg (urgent), and undefined. |
WORD<1–60> |
Specifies the destination port: (0–65535), or echo, ftpdata, ftpcontrol, ssh, telnet, dns, http, hdot323, bootpServer, bootpClient, tftp, rtp, rtcp, or undefined. |
WORD<1–200> |
Specifies the ICMP message type: Icmpmsg type (0–255), or echoreply, destunreach, sourcequench, redirect, echo-request, routeradv, routerselect, time-exceeded, param-problem, timestamp-request, timestamp-reply, addressmask-request, addressmask-reply, or traceroute. |
WORD<1–200> |
Specifies the ICMPv6 message type: Icmpmsg type (0-255), or destUnreach, pktTooBig, timeExceeded, paramProblem, echoRequest, echoReply, mcastListenReq, mcastListenRpt, mcastListenDone, routerSolicit, routerAdvert, neighborSolicit, neighborAdvert, redirectMsg, nodeInfoReq, nodeInfoRsp, or v2McastListenRpt. |
WORD<1–256> |
Specifies the mask parameter, {0-0xFFFF}. |
WORD<0–65535> |
Specifies the source port (0–65535). |
