Extend System Message Control
Use the force message control option to extend the message control feature functionality to the software and hardware log messages.
To enable the message control feature, you must specify an action, control interval, and maximum message number. After you enable the feature, the log messages, which get repeated and cross the maximum message number in the control interval, trigger the force message feature. You can either suppress the message or send a trap notification, or both.
Switch:1> enable
Switch:1# configure terminal
Configure the force message control option. (If you specify the wildcard pattern (****), then all messages undergo message control:
Switch:1(config)# sys force-msg ****
The following table defines parameters for the sys force-msg command.
 Variable  |
 Value  |
 WORD<4-4>  |
 Adds a forced message control pattern, where WORD<4-4> is a string of 4 characters. You can add a four-byte pattern into the force-msg table. The software and the hardware log messages that use the first four bytes that match one of the patterns in the force-msg table undergo the configured message control action. You can specify up to 32 different patterns in the force-msg table, including a wildcard pattern (****) as well. If you specify the wildcard pattern, all messages undergo message control.  |
