Use this procedure to insert a FA Zero Touch Client.
                In the navigation pane, expand
                Select Fabric
                    Attach.
                Select the Zero Touch Client Auto
                        Attach tab.
                Select Insert.
                    The Insert Zero
                            Touch Client dialog box opens.
                In the Type field,
                    select the ellipsis and select a client.
                Select Ok
                    to select the client or Refresh to update
                    the list.
                In the Isid field, enter
                    the I-SID value.
                    The I-SID value is between 0 and 16777214.
                Select Insert.
