BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Support Matrix.
Use the following procedure to display BFD configuration on an IPv6 interface.
The following example displays port configuration information for BFD.
Switch:1>show ipv6 bfd interfaces gigabitethernet 1/3
                                    Port Bfd
PORT       STATUS     MIN_RX     INTERVAL   MULTIPLIER      VRF-ID
1/3        enable     200        200            3           0
The following table defines parameters for the show ip bfd interfaces command.
                             Variable  |
                             Value  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                             <1-4059>  |
                             Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
                             vrf WORD<1-16>  |
                             Specifies a VRF instance by VRF name.  |
                             vrfids WORD<0-512>  |
                             Specifies a VRF or range of VRFs by ID.  |
