Configure a static foreign source on the global router. Configuration is done at the Controller. Statically configure foreign sources, such as streams in a Source Specific Multicast (SSM) group range that are not advertised by the foreign network through MSDP. Non-SSM range group multicast address streams are advertised by MSDP and do not need to be statically configured.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip spb-pim-gw foreign-source 10.0.0.1 group 240.0.0.1
Variable definitions
The following table defines parameters for the ip spb-pim-gw command.
 Variable  |
 Value  |
 foreign-source{A.B.C.D}  |
 Specifies the multicast foreign source IP address.  |
 group{A.B.C.D}  |
 Specifies the group IP address.  |
