Use the following procedure to display the Authenticator Port Access Entity (PAE) statistics for each selected port.
EAPOL Stats Field Descriptions
The following table describes values on the EAPOL Stats tab.
                                 Name  |
                                 Description  |
                                 InvalidFramesRx  |
                                 Displays the number of EAPoL frames received by this Authenticator in which the frame type is not recognized.  |
                                 EapLengthErrorFramesRx  |
                                 Displays the number of EAPoL frames received by this Authenticator in which the Packet Body Length field is invalid.  |
                                 StartFramesRx  |
                                 Displays the number of EAPoL start frames received by this Authenticator.  |
                                 EapFramesRx  |
                                 Displays the number of EAPoL-EAP frames received by this Authenticator.  |
                                 LogoffFramesRx  |
                                 Displays the number of EAPoL Logoff frames received by this Authenticator.  |
                                 LastRxFrameVersion  |
                                 Displays the last received version of the EAPoL frame by this Authenticator.  |
                                 LastRxFrameSource  |
                                 Displays the source MAC address of the last received EAPoL frame by this Authenticator.  |
                                 AuthEapFramesTx  |
                                 Displays the number of EAPoL-EAP frames transmitted by the Authenticator.  |
