Use the following procedure to configure an aging interval for IPFIX. The aging interval determines how long a traffic flow that is no longer being received, is retained as a flow.
    enable
    configure terminal
  2. Configure a value for the aging interval:
    ip ipfix aging-interval <1-60>
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#ip ipfix aging-interval 30
The following table defines parameters for the ip ipfix aging-interval command.
Variable
Value
<1-60>
Specifies, in seconds, the flow record aging interval. The aging interval determines how long a traffic flow that is no longer being received is retained as a flow.
The default is 40 seconds.
