View ACL Statistics
Graph statistics for a specific ACL ID to view default statistics.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select an ACL.
- Select Graph.
- Optional: Select Clear Counters to clear the fields.
Statistics Field Descriptions
Use the data in the following table to use the Statistics tab.
Based on your hardware platform, the output can display the ACL packets by ACE type or Primary Bank or Secondary Bank.
Name |
Description |
AclId |
Specifies the ACL ID. |
MatchDefaultSecurityPkts Note:
Exception: not supported on VSP 7400 Series. |
Shows a security packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultPrimaryBankPkts Note:
Exception: only supported on VSP 7400 Series. |
Shows a Primary Bank packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultSecurityOctets Note:
Shows a security byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultPrimaryBankOctets Note:
Shows a Primary Bank byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultQosPkts Note:
Shows a QoS packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultSecondaryBankPkts Note:
Shows a Secondary Bank packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultQosOctets Note:
Shows a QoS byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultSecondaryBankOctets Note:
Shows a Secondary Bank byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalSecurityPkts Note:
Shows a security packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalPrimaryBankPkts Note:
Shows a Primary Bank packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalSecurityOctets Note:
Shows a security byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalPrimaryBankOctets Note:
Shows a Primary Bank byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalQosPkts Note:
Shows a QoS packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalSecondaryBankPkts Note:
Shows a Secondary Bank packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalQosOctets Note:
Shows a QoS byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalSecondaryBankOctets Note:
Shows a Secondary Bank byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
DefaultGreenBytes |
Shows byte count of traffic sent with a rate lower than committed-rate matching any of the ACE rules or hits on Default Action. |
DefaultGreenPackets |
Shows packet count of traffic sent with a rate lower than committed-rate matching any of the ACE rules or hits on Default Action. |
DefaultYellowBytes |
Shows byte count of traffic sent with a rate lower than peak-rate and higher than committed-rate matching any of the ACE rules or hits on Default Action. |
DefaultYellowPackets |
Shows packet count of traffic sent with a rate lower than peak-rate and higher than committed-rate matching any of the ACE rules or hits on Default Action. |
DefaultRedBytes |
Shows byte count of traffic sent with a rate higher than peak-rate matching any of the ACE rules or hits on Default Action. |
DefaultRedPackets |
Shows packet count of traffic sent with a rate higher than peak-rate matching any of the ACE rules or hits on Default Action. |
