Configure a black hole static route to the destination a router advertises to avoid routing loops after the router aggregates or injects routes to other routers.
If a black hole route is enabled, you must first delete or disable it before you can add a regular static route to that destination.
Only black hole routes that belong to the static type protocol are supported. An inter-VRF black hole route is not installed in the routing table of the destination VRF on the same switch.
Create a black hole static route and enable the black hole static route.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip route 192.0.2.0 255.255.0.0 255.255.255.255 weight 200 Switch:1(config)#ip route 192.0.2.0 255.255.0.0 255.255.255.255 enable
The following table defines parameters for the ip route command.
                             Variable  |
                             Value  |
                             <A.B.C.D A.B.C.D | A.B.C.D/X>  |
                             Specifies the IP address and mask for the route destination in one of the following formats:
 255.255.255.255 is the destination of the black hole route.  |
                             enable  |
                             Adds a static route to the router or VRF.  |
                             local-next-hop enable  |
                             Enables the local next hop for this static route.  |
                             next-hop-vrf WORD<1-16>  |
                             Specifies the next-hop VRF instance by name.  |
                             weight <1-65535>  |
                             Specifies the static route cost. Note:
                            Do not configure a static interface subnet route with a weight of 1.  |
                             preference <1-255>  |
                             Specifies the route preference.  |
