View VRRP statistics to manage network performance.
 - Select VRRP.
 - Select the Interface tab.
 - Select an interface.
 - Select Graph.
Interface Field Descriptions
The following table describes parameters on the Interface tab.
 Name  |
 Description  |
 AdvertiseRcvd  |
 Specifies the number of VRRP advertisements received by this virtual router.  |
 AdvertiseIntervalErrors  |
 Specifies the number of received VRRP advertisement packets with a different interval is than configured for the local virtual router.  |
 IPTtlErrors  |
 Specifies the number of VRRP packets received by the virtual router with IP TTL (Time-To-Live) not equal to 255.  |
 PriorityZeroPktsRcvd  |
 Specifies the number of VRRP packets received by the virtual router with a priority of 0.  |
 PriorityZeroPktsSent  |
 Specifies the number of VRRP packets sent by the virtual router with a priority of 0'.  |
 InvalidTypePktsRcvd  |
 Specifies the number of VRRP packets received by the virtual router with an invalid value in the 'type' field.  |
 AddressListErrors  |
 Specifies the packets received address list the address list does not match the locally configured list for the virtual router.  |
 AuthTypeMismatch  |
 Specifies the count of authentication type mismatch messages.  |
 PacketLengthErrors  |
 Specifies the count of packet length errors.  |
 AuthFailures  |
 Specifies the count of authentication failure messages.  |
