View RIP status
View RIP status.
 - Select RIP.
 - Select the Status tab.
Status Field Description
Use the data in the following table to use the RIP Status tab.
 Name  |
 Description  |
 Address  |
 Specifies the IP address of the router interface.  |
 RcvBadPackets  |
 Specifies the number of RIP response packets received by the RIP process which were subsequently discarded; for example, version 0 packet, or an unknown command type.  |
 RcvBadRoutes  |
 Specifies the number of routes, in valid RIP packets, that are ignored; for example, unknown address family, or invalid metric.  |
 SentUpdates  |
 Specifies the number of triggered RIP updates sent on this interface, that do not include full updates sent containing new information.  |
