View OSPF Errors on a Port
Check OSPF errors for administrative and troubleshooting purposes.
Variable definitions
The following table defines parameters for the show ip ospf port-error command.
Variable |
Value |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
vrf WORD<1-16> |
Specifies the VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRFs by ID number. |
