Configure BGP globally to enable BGP on the switch and determine how BGP operates.
To configure the suppress-map, advertise-map, or attribute-map options, the route policy for those options must exist.
For initial BGP configuration, you must know the AS number.
You configure BGP on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip bgp. The VRF must have an RP Trigger of BGP.
Route refresh is not currently supported on non-default VRFs.
Specify the AS number and enable BGP:
Switch(config)#router bgp 3 enable
Access Router BGP Configuration mode:
Switch(router-bgp)#
The following table defines parameters for the router bgp command.
                             Variable  |
                             Value  |
                             WORD <0-11>  |
                             Specifies the AS number. You cannot enable BGP until you change the local AS to a value other than 0.  |
                             enable  |
                             Enables BGP on the router.  |
Use the data in the following table to use the BGP variables in BGP and VRF Router Configuration mode.
                             Variable  |
                             Value  |
                             aggregate-address WORD<1-256>  |
                             Specifies an IP address and its length in the form {a.b.c.d/len}, or an IPv6 address and its length in the form {ipv6addr/len}.  |
                             auto-peer-restart enable  |
                             Enables the process that automatically restarts a connection to a BGP neighbor. The default value is enable.  |
                             auto-summary  |
                             When enabled, BGP summarizes networks based on class limits, for example, Class A, B, and C networks. The default value is enable.  |
                             bgp always-compare-med  |
                             Enables the comparison of the multi-exit discriminator (MED) parameter for paths from neighbors in different autonomous systems. The system prefers a path with a lower MED over a path with a higher MED. The default value is disable.  |
                             bgp aggregation  |
                             Enables the aggregation feature on the interface.  |
                             bgp client-to-client reflection  |
                             Enables or disables route reflection between two route reflector clients. This variable applies only if the route reflection value is enable. The default value is disable. You can enable route reflection even when clients are fully meshed. This variable only applies to VRF 0. Example: Switch(router-bgp)# bgp client-to-client reflection System Response: Restart or soft-restart BGP for the change to take effect.  |
                             bgp cluster-id {A.B.C.D}  |
                             Configures a cluster ID. This variable applies only if the route reflection value is enable, and if multiple route reflectors are in a cluster. {A.B.C.D} is the IP address of the reflector router. This variable only applies to VRF 0. Example: Switch(router-bgp)# bgp cluster-id 0.0.0.0  |
                             bgp confederation identifier <0-4294967295> [peers WORD<0-255>]  |
                             Configures a BGP confederation. identifier<0-4294967295> specifies the confederation identifier. Use 0–65535 for 2-byte AS and <0-4294967295> for 4-byte AS. peers WORD<0-255> lists adjoining autonomous systems that are part of the confederation in the format (5500,65535,0,10,...,...). Use quotation marks (") around the list of autonomous systems. Note:
                            Use this command only on VRF 0. Example: Switch(router-bgp)# bgp confederation identifier 1 peers “20 30 40”  |
                             bgp default local-preference <0-2147483647>  |
                             Specifies the default value of the local preference attribute. The default value is 0. You must disable BGP before you can change the default value. Example: Switch(router-bgp)# bgp default local-preference 2–12  |
                             bgp deterministic-med enable  |
                             Enables deterministic MED. Example: Switch(router-bgp)# bgp deterministic-med enable  |
                             bgp multiple-paths <1-8>  |
                             Configures the maximum number of equal-cost-paths that are available to a BGP router by limiting the number of equal-cost-paths the routing table can store. The default value is 1. Example: Switch(router-bgp)# bgp multiple-paths 4 Note:
                        Configuring the bgp multiple-paths variable does not affect existing routes. The routing table does not show ECMP routes; instead only one route is shown in the routing table. To view Equal-Cost Multipath (ECMP) routes, receive the routes after executing the bgp multiple-paths variable, or toggle the BGP state. The number of equal-cost-paths supported can differ by hardware platform. For more information, see VOSS Release Notes.  |
                             comp-bestpath-med-confed enable  |
                             When enabled, compares MED attributes within a confederation. The default value is disable. This variable only applies to VRF 0. Example: Switch(router-bgp)# comp-bestpaht-med-confed enable Restart or soft-restart BGP for the change to take effect  |
                             debug-screen <off|on>  |
                             Displays debug messages on the console, or saves them in a log file. Disable BGP screen logging (off) or enable BGP screen logging (on). Example: Switch(router-bgp)# debug-screen on System Response:BGP Screen Logging is On  |
                             default-information originate  |
                             Enables the advertisement of a default route to peers, if the route exists in the routing table. The default value is disable.  |
                             default-information ipv6-originate  |
                             Enables the advertisement of an IPv6 default route to peers, if the route exists in the routing table. The default value is disable.  |
                             default-metric <-1-2147483647>  |
                             Configures a value to send to a BGP neighbor to determine the cost of a route a neighbor uses. A default metric value solves the problems associated with redistributing routes that use incompatible metrics. For example, whenever metrics do not convert, using a default metric provides a reasonable substitute and redistribution proceeds. Use this option in conjunction with the redistribute commands so the current routing protocol uses the same metric for all redistributed routes. The default value is 0.  |
                             flap-dampening enable  |
                             Enables route suppression for routes that flap on and off. The default value is disable.  |
                             global-debug mask WORD<1-100>  |
                             Displays specified debug information for BGP global configurations. The default value is none.
 Mask choices are:
 Example: Switch(router-bgp)# global-debug mask event, trace, warning, state  |
                             ibgp-report-import-rt enable  |
                             Configures BGP to advertise imported routes to an interior BGP (iBGP) peer. This variable enables or disables advertisement of nonBGP imported routes to other iBGP neighbors. The default value is enable.  |
                             ignore-illegal-rtrid enable  |
                             When enabled, BGP overlooks an illegal router ID. For example, you can configure this variable to enable or disable the acceptance of a connection from a peer that sends an open message using a router ID of 0 (zero). The default value is enable.  |
                             neighbor-debug-all mask WORD<1-100>  |
                             Displays specified debug information for BGP neighbors. The default value is none. For mask options, see the global-debug mask WORD<1-100> variable. Example: Switch(router-bgp)# neighbor-debug-all mask error, packet, event.trace, state, filter  |
                             no-med-path-is-worst enable  |
                             Enables BGP to treat an update without a MED attribute as the worst path. The default value is disable.  |
                             quick-start enable  |
                             Enables the quick-start flag for exponential backoff.  |
                             route-reflector enable  |
                             Enables the reflection of routes from iBGP neighbors. The default value is disable. This variable only applies to VRF 0.  |
                             route-refresh  |
                             Enables or disables route refresh. If enabled, a route refresh request received by a BGP speaker causes the speaker to resend all route updates it contains in its database that are eligible for the peer that issues the request. This variable only applies to VRF 0.  |
                             router-id {A.B.C.D}  |
                             Specifies the BGP router ID in IP address format. This variable only applies to VRF 0.  |
                             synchronization  |
                             Enables the router to accept routes from BGP peers without waiting for an update from the IGP. The default value is enable.  |
                             traps enable  |
                             Enables BGP traps.  |
                             vrf-as WORD<0-11>  |
                             Configures an AS number on a specific VRF instance. Use 0–65535 for a 2-byte AS and <0-4294967295> for a 4-byte AS. The default value of 0, or configuring the local-as in the VRF to 0, is equivalent to deleting the local-as configured on user-defined VRFs, and in both cases the local-as on the VRF becomes the local-as on the GlobalRouter.  |
Job Aid
Use debug command values to control debug messages for global BGP message types, and for message types associated with a specified BGP peer or peer group.
Tip
The following tips can help you use the debug commands:
Display debug commands for multiple mask choices by entering the mask choices separated by commas, with no space between choices.
To end (disable) the display of debug messages, use the mask choice of none.
You can save debug messages in a log file, or you can display the messages on your console using the debug-screen command.
For more information about the logged debug messages, see VOSS Alarms and Logs Reference.
