Use this procedure to determine the protocol configured on the added VLAN.
The protocol configured on the added VLAN can be one of the following values:
snoop
snoop-spb
route-spb
pim
Determine the protocol configured on the added VLAN:
Switch:1#show ip igmp interface vrf l3vsn-100
Igmp Interface - VRF l3vsn-100
QUERY OPER QUERY WRONG LASTMEM SCOPE
IF INTVL STATUS VERS. VERS QUERIER MAXRSPT QUERY JOINS ROBUST QUERY MODE L2ISID ISID
V10 125 inact 2 2 0.0.0.0 100 0 0 2 10 routed-spb 0 100
The following table defines parameters for the show ip igmp interface command.
Variable |
Value |
gigabitethernet{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
vlan<1-4059> |
vrfWORD<1–16> |
Specifies the VRF instance by the VRF name. |
vrfidsWORD<0–512> |
Specifies the VRF ID for which to display statistics. |
