Assign IPv6 addresses to interfaces to configure IPv6 routing for the interface.
You can assign an IPv6 address to a VLAN or brouter port.
Change the VRF instance as required to assign IPv6 addresses to a brouter port interface on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
To create MLT and LAG interfaces with IPv6, you must configure VLAN-based connections and you cannot use brouter ports.
 - Select IPv6.
 - Select the Ipv6 Addresses tab.
 - Select Insert.
 - Select Insert.
 - Select Apply.
IPv6 Addresses Field Descriptions
Use the data in the following table to use the IPv6 Addresses tab.
 Name  |
 Description  |
 Interface  |
 Specifies the port.  |
 Addr  |
 Specifies the IPv6 address to which this entry applies. Note:
If the IPv6 address exceeds 116 octets, the object identifiers (OIDS) of instances of columns in this row are more than 128 subidentifiers and you cannot use SNMP-v1, SNMPv2c, or SNMPv3 to access them.  |
 AddrLen  |
 Specifies the prefix length value for this address. You cannot change the address length after you create it. You must provide this value to create an entry in this table.  |
 Type  |
 Specifies the type of address. The default is unicast.  |
 Origin  |
 Specifies the origin of the address.  |
 Status  |
 Specifies the status of the address, describing whether the address is used for communication.  |
 Created  |
 Specifies the sysUpTime of the creation of this entry. If the entry was created prior to the last reinitialization of the local management subsystem, the object contains a zero value.  |
 LastChanged  |
 Specifies the value of sysUpTime of the last modification to this entry. If the entry was created prior to the last reinitialization of the local management subsystem, the object contains a zero value.  |
