Use the following procedure to configure the VXLAN Gateway source IP address.
- Select VTEP.
- Select the Globals tab.
- In the SourceIp field, type the VTEP source IP address.
- In the Vrf field, select GlobalRouter or a VRF ID.
- Select Apply.
Use the data in the following table to use the Globals tab.
Name |
Description |
SourceIp |
Specifies the VXLAN tunnel end point (VTEP) source IP address in an A.B.C.D format. |
Vrf |
Specifies the VRF name used for the source IP address, which you select from the drop down menu. This IP address can be on the GRT or a VRF. Note:
The VTEP source IP address must be on a loopback interface. |
