Display information about the files in internal flash memory on this device.
 - Select File System.
 - Select the Flash Files tab.
Flash Files Field Descriptions
Use the data in the following table to use the Flash Files tab.
 Name  |
 Description  |
 Slot  |
 Specifies the slot number.  |
 Name  |
 Specifies the directory name of the file.  |
 Date  |
 Specifies the creation or modification date of the file.  |
 Size  |
 Specifies the size of the file.  |
