Perform the following procedure to configure the PoE power usage threshold limit globally as a percentage on the switch. The switch logs a warning message when a PoE PD power usage exceeds the configured threshold. The switch logs an informational message when a PoE PD power usage is below the configured threshold.
The following table defines parameters for the poe-power-usage-threshold command.
 Variable  |
 Value  |
 <1–99>  |
 Specifies the PoE usage threshold in the range of 1—99 percent.  |
