Display the existing software licenses on your device. If the switch uses a Factory Default Premier Trial License, the output shows the time remaining in the trial period.
  1. To enter User EXEC mode, log on to the switch.
  2. Show the existing software licenses on your device:
    show license
Example outputs might not be identical on all hardware platforms.
The following output is shows time remaining on a Trial License for non-universal hardware when the trial period is extended:
Switch:1>show license
License Type                     : 1) BASE
                                   2) PREMIER TRIAL (non-Base features)
Premier TrialPeriodRemainingDays  : 117
Features requiring a Premier license:
        -  Layer 3 VSNs
        -  MACsec
        -  Distributed Virtual Routing(DvR) Controller
        -  VXLAN GATEWAY
        -  >16 BGP Peers
        -  Insight Virtualization
