Use the following procedure to display the IPv6 unicast Forwarding Information Base (FIB). The tab shows IPv6 routes from remote Backbone Edge Bridges (BEBs)
In SPBM, each node has a System ID, which also serves as Backbone MAC address (B-MAC) of the switch. These Backbone MAC addresses are populated into the SPBM VLAN Forwarding Information Base (FIB). When the network topology is discovered and stored in the IS-IS link-state database, each node calculates shortest path trees for each source node, so that a unicast path now exists from every node to every other node. With this information, each node populates unicast information received from SPBM into the FIB for forwarding purposes.
I-SIDs are only used for virtual services (Layer 2 VSNs and Layer 3 VSNs). If you only enable IP Shortcuts on the Backbone Edge Bridges, I-SIDs are never exchanged in the network as IP Shortcuts allows for Global Routing Table (GRT) IP networks to be transported across IS-IS.
 - Select SPBM.
 - Select the IPv6 Unicast FIB tab.
IPv6 Unicast FIB Field Descriptions
Use the data in the following table to use the IPv6 Unicast FIB tab.
 Name  |
 Description  |
 VrfId  |
 Specifies the VRF ID of the IPv6 unicast FIB entry, 0 indicates NRE.  |
 DestinationIpAddrType  |
 Specifies the address type of the destination IPv6 address.  |
 DestinationIpAddr  |
 Specifies the destination IPv6 Address of the IPv6 unicast FIB entry.  |
 DestinationMask  |
 Specifies the destination IPv6 mask of the IPv6 unicast FIB entry  |
 NextHopBmac  |
 Specifies the nexthop B-MAC of the IPv6 unicast FIB entry.  |
 DestIsid  |
 Specifies the destination I-SID of the IPv6 unicast FIB entry.  |
 Vlan  |
 Specifies the VLAN of the IPv6 unicast FIB entry.  |
 Isid  |
 Specifies the I-SID of the IPv6 unicast FIB entry.  |
 NextHopName  |
 Specifies the nexthop hostname of the IPv6 unicast FIB entry.  |
 OutgoingPort  |
 Specifies the outgoing port of the IPv6 unicast FIB entry.  |
                                 PrefixCost  |
                                 Specifies the prefix cost of the IPv6 unicast FIB entry.  |
 SpbmCost  |
 Specifies the B-MAC cost of the IPv6 unicast FIB entry.  |
                                 MetricType  |
                                 Specifies the Metric Type of the IPv6 unicast FIB entry.  |
