 - Select IPv6 Mroute.
 - Select the Route tab.
Route Field Descriptions
Use the data in the following table to use the Route tab.
 Name  |
 Description  |
                                 Group  |
                                 Displays the IPv6 multicast group for this entry that specifies a next hop on an outgoing interface.  |
                                 Source  |
                                 Displays the network address that, when combined with the corresponding next hop SourceMask value, identifies the source for this entry that specifies a next hop on an outgoing interface.  |
                                 SourceMask  |
                                 Displays the network mask that, when combined with the corresponding next hop Source value, identifies the source for this entry that specifies a next hop on an outgoing interface.  |
                                 UpStreamNeighbor  |
                                 Shows the address of the upstream neighbor from which the IPv6 datagrams from these sources are received.  |
                                 IfIndex  |
                                 Displays the slot and port number or VLAN ID for this entry.  |
                                 ExpiryTime  |
                                 Displays the minimum amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging.  |
                                 Protocol  |
                                 Displays the protocol as one of the following:
