Configure Layer 2 Ping
  • On the source and destination nodes, you must configure a CFM MD, MA, and MEP, and assign a nodal MEP to the B-VLAN.
Use this procedure to configure a Layer 2 ping inside an SPBM cloud or network. This feature enables CFM to debug Layer 2. It can also help you debug IP shortcuts and the record for the shortcuts‘ ARP.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics.
  2. Select L2Ping/L2Trace Route.
  3. From the L2Ping tab, configure the Layer 2 ping properties.
  4. To initiate a Layer 2 ping, highlight an entry, and then select Start.
  5. To update a Layer 2 ping, select Refresh.
  6. To stop the Layer 2 ping, select Stop.
L2Ping Field Descriptions
Use the data in the following table to use the L2Ping tab.
Name
Description
VlanId
Identifies the backbone VLAN.
DestMacAddress
Specifies the target MAC address.
HostName
Specifies the target host name.
DestIsHostName
Indicates whether the host name is (true) or is not (false) used for L2Ping transmission.
Messages
Specifies the number of L2Ping messages to be transmitted. The default is 1.
Status
Specifies the status of the transmit loopback service:
  • ready: the service is available.
  • transmit: the service is transmitting, or about to transmit, the L2Ping messages.
  • abort: the service aborted or is about to abort the L2Ping messages.
This field is also used to avoid concurrency or race condition problems that can occur if two or more management entities try to use the service at the same time.
The default is ready.
ResultOk
Indicates the result of the operation:
  • true: the L2Ping Messages will be (or have been) sent.
  • false: the L2Ping Messages will not be sent.
The default is true.
Priority
Specifies a 3–bit value to be used in the VLAN header, if present in the transmitted frame.
The default is 7.
TimeoutInt
Specifies the interval to wait for an L2Ping time-out. The default value is 3 seconds.
TestPattern
Specifies the test pattern to use in the L2Ping PDU:
  • allZero: null signal without cyclic redundancy check
  • allZeroCrc: null signal with cyclic redundancy check with 32-bit polynomial
  • pseudoRandomBitSequence: pseudo-random-bit-sequence without cyclic redundancy check
  • pseudoRandomBitSequenceCrc: pseudo-random-bit-sequence with cyclic redundancy check with 32-bit polynomial.
A cyclic redundancy check is a code that detects errors. The default value is allZero.
DataSize
Specifies an arbitrary amount of data to be included in the data TLV, if the data size is selected to be sent. The default is 0.
FrameSize
Specifies the frame size. If the frame size is specified then the data size is internally calculated and the calculated data size is included in the data TLV. The default is 0.
SourceMode
Specifies the source mode of the transmit loopback service:
  • nodal
  • noVlanMac — Use this value with C-VLAN only. When you select this option, even if a VLAN MAC address exists, the system uses the CFM C-MAC as the BMAC-SA.
  • smltVirtual — Use the smltVirtual option with B-VLANs only.
The default is nodal.
SeqNumber
The transaction identifier/sequence number of the first loopback message (to be) sent. The default is 0.
Result
Displays the Layer 2 Ping result.
