Display the RSTP Role
Perform the following procedure to display the RSTP information.
Display the RSTP role:
                           RSTP Port Roles and States
Port-Index  Port-Role    Port-State   PortSTPStatus  PortOperStatus
1/3        Designated   Forwarding   Enabled        Enabled
 Variable definitions
Use the data in the following table to use optional parameters with the show spanning-tree rstp port role command.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
