Perform the following procedure to view information about the package files available in the /var/lib/insight/packages directory, which you can use to install a new virtual service.
 - Select Virtual Service.
 - Select the PackageFile tab.
PackageFile Field Descriptions
Use data in the following table to use the PackageFile tab.
                         Name  |
                         Description  |
                         Name  |
                         Shows the name and absolute path information for package files available in the /var/lib/insight/packages directory.  |
                         Date  |
                         Shows the date and time when the package file was added to the directory.  |
                         Size  |
                         Shows the size (in bytes) of the package file.  |
