Perform this procedure to configure the optional parameters on existing SPB-PIM Gateway interfaces.
 - Select SPB-PIM-GW.
 - Select the Interfaces tab.
 - In the row for the interfaces, double-click HelloInterval, and then type the hello interval in seconds.
 - In the row for the interfaces, double-click JoinPruneInterval, and then type the join prune interval in seconds.
 - Select Apply.
Interfaces Field Descriptions
Use the data in the following table to use the Interfaces tab.
 Name  |
 Description  |
 IfIndex  |
 Shows the interface index.  |
 OperState  |
 Shows the operational state of the interface.  |
 AddressType  |
 Shows the address type of the interface.  |
 Address  |
 Shows the address assigned to the interface.  |
 AddressMask  |
 Shows the address mask associated with the interface address.  |
 HelloInterval  |
 Configures the PIM HELLO transmission interval. The default is 30 seconds.  |
 JoinPruneInterval  |
 Configures the PIM JOIN PRUNE transmission interval. The default is 60 seconds.  |
