Configure broadcast/unknown unicast and multicast bandwidth limiting to limit the amount of ingress traffic on a port. The switch drops traffic that violates the bandwidth limit.
The following table defines parameters for the rate-limit command.
                                 Variable  |
                                 Value  |
                                 <1-65535>  |
                                 Specifies the bandwidth limit for broadcast/unknown unicast and multicast traffic, in packets per second (pps).  |
                                 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
                                 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
