Configure ELAN Endpoints
Use the following procedure to configure information associated with ELAN end points.
 - Select VTEP.
 - Select the Elan End Points tab.
 - In Vnid, specify the VNID associated with this ELAN.
 - In Cvid, specify the customer VLAN ID.
 - In IfIndex, specify the interface index for this ELAN endpoint.
 - Select Apply.
Elan End Points Field Descriptions
Use the data in the following table to use the Elan End Points tab.
 Name  |
 Description  |
 Vnid  |
 Specifies a value that uniquely identifies the VNID of this ELAN tunnel end point.  |
 Cvid  |
 Specifies a value that uniquely identifies the customer VLAN ID of this ELAN endpoint. The switch reserves the following VLAN IDs:
 IfIndex  |
 Specifies the interface index for the MLT or port for this ELAN endpoint.  |
 Isid  |
 Specifies the I-SID associated with this VNID.  |
