Configure the serial port devices to define connection settings for the console port.
Switch:1>enable Switch:1#config terminal Switch:1(config)#show boot config sio sio console baud 115200 1
The following table defines parameters for the boot config sio console command.
                                                 Variable  |
                                                 Value  |
                                                 baud <115200>  |
                                                 Configures the baud rate for the port. The default is 115200.  |
