Create NTPv4 Restrict Entries
You must enable NTPv4 server master mode. For more information, see Configure NTP Globally.
Perform the following procedure to configure the NTP restrict capability for a specific IPv4 or IPv6 address(es), which means the switch permits traffic flow from the specified IP address only. By default the NTP restrict capability is disabled.
You can configure a maximum of 128 NTP Restrict entries (IPv4 or IPv6 addresses).
0.0.0.0/0 or ::/0 NTP restrict entries are equivalent to no NTP restrict rules configured.
 - Select Restrict.
 - Select the Restrict Info tab.
 - Select Insert.
 - In RowIndex, type a value.
 - Select the IP address type.
 - Type the IPv4 or IPv6 address.
 - Type the restrict mask value.
 - Select Insert.
Restrict Info Field Descriptions
Use data in the following table to use the Restrict Info tab.
                         Name  |
                         Description  |
                         RowIndex  |
                         Specifies the NTP Restrict entry.  |
                         AddressType  |
                         Specifies the NTP Restrict address type.  |
                         RestrictAddress  |
                         Specifies the NTP address to be restricted.  |
                         RestrictMask  |
                         Specifies the prefix length of the IPv4 or IPv6 NTP address to be restricted.  |
