Display information about BGPv6 redistributed routes.
The following table defines parameters for the show bgp ipv6 redistributed-routes command.
                             Variable  |
                             Value  |
                             vrf  |
                             Specifies a VRF instance by name (the string length ranges from 1–16 characters).  |
                             vrfids  |
                             Specifies a range of VRFs by ID number (the ID ranges from 0–255).  |
