Use this task to configure a DHCP Client on a management interface.
  1. In the navigation pane, expand Configuration > Edit > Mgmt Instance.
  2. Select Mgmt.
  3. Select the Dhcp tab.
  4. In Client, select an option to configure the DHCP Client.
  5. Select Apply.
Dhcp Field Descriptions
Use the data in the following table to use the Dhcp tab.
Name
Description
Client
Specifies the DHCP client configuration:
  • oob - DHCP Client on the Out-of-Band management interface.
  • vlan - DHCP Client on the VLAN management interface.
  • cycle - DHCP Client cycles between in-band and Out-of-Band management interfaces until an IP address is obtained on one management interface.
  • disable - DHCP Client is disabled.
ClientPreferredInterface
Shows the DHCP Client preferred management interface when in cycle mode. On reboot, the system first attempts to aquire a DHCP IP address on the preferred interface.
