Configure a Candidate RP
Configure a C-RP router to add it to the RP Set.
You can configure only one interface on a switch for multiple groups.
Use the GroupMask value to configure a candidate RP for several groups in one configuration. For example, if you use a C-RP configuration with a GroupAddress value of 224.0.0.0 and a GroupMask of 240.0.0.0, you can configure the C-RP router for a multicast range from 224.0.0.0 to 239.255.255.255.
 - Select PIM.
 - Select the Candidate RP tab.
 - Select Insert.
 - Configure the required parameters.
 - Select Insert.
Candidate RP Field Descriptions
Use the descriptions in the following table to use the Candidate RP tab.
 Name  |
 Description  |
 GroupAddress  |
 Configures the IP address of the multicast group. When combined with the group mask, this value identifies the prefix that the local router uses to advertise itself as a C-RP router.  |
 GroupMask  |
 Configures the address mask of the multicast group. When combined with the group address, this value identifies the prefix that the local router uses to advertise itself as a C-RP router.  |
 InterfaceAddress  |
 Configures the IP address of the C-RP router. This address must be one of the local PIM-SM enabled interfaces.  |
