Enable and configure polling intervals to determine how frequently EDM polls for port and LED status changes, or detects the hot swap of installed ports.
 - Select Preference Setting.
 - Enable polling or hot swap detection.
 - Configure the frequency to poll the device.
 - Select Apply.
Preference Setting Field Descriptions
Use the data in the following table to use the Preference Setting tab.
 Name  |
 Description  |
 Enable  |
 Enables polling for port and LED status changes. The default is disabled.  |
 Poll Interval  |
 Specifies the polling interval, if enabled. The default is 60 seconds.  |
 Enable  |
 Detects the hot swap of installed ports. The default is disabled.  |
 Detection per Status Poll Intervals  |
 Specifies the number of poll intervals for detection, if enabled. The default is 2 intervals.  |
