Use the following procedure to configure the format of the RADIUS password when authenticating NEAP MAC addresses using RADIUS.
The following table defines parameters for the eapol multihost non-eap-pwd-fmt command.
Variable |
Value |
ip-addr |
Management ip-address of the switch. |
key WORD<1-32> |
Key value used for non-eap password format. |
mac-addr |
Mac-Address of the client. |
padding |
Includes a dot in the RADIUS password for every missing parameter. |
port-number |
Index of the port on which MAC is received. |
To derive the port number for an interface, use the command show interfaces gigabit [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}] .
If you configure interface 1/6 on the product, to derive the port-number for this interface, use the command show interfaces gigabitEthernet 1/6. From this command, you can ascertain that port number used in the NEAP password is 197.
Switch:1(config)# show interfaces gigabitEthernet 1/6
Port Interface
PORT LINK PORT PHYSICAL STATUS
NUM INDEX DESCRIPTION TRAP LOCK MTU ADDRESS ADMIN OPERATE
1/6 197 1000BaseTX true false 1950 f8:15:47:e1:dd:05 up up
