Configure IP Shortcuts on the boundary nodes.
Perform this procedure to configure Multi-area SPB IPv4 unicast redistribution on the switch.
Configuring Multi-area SPB IPv4 unicast redistribution for home to remote direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote
Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote route-map test
Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote enable
Switch:1(config-isis)#show isis multi-area ip redistribute home-to-remote
         ISIS Multiarea Redistribute List for ip unicast - GlobalRouter
DIRECTION            ENABLE     RPOLICY
home-to-remote       TRUE       test
Switch:1(config-isis)#isis multi-area ip apply redistribute unicast home-to-remote
The following table defines parameters for the multi-area ip redistribute unicast and the isis multi-area ip apply redistribute unicast commands.
| Variable | Value |
| enable |
                                 Enables Multi-area SPB IPv4 unicast redistribution.  |
| home-to-remote |
                                 Specifies the IPv4 unicast redistribution configuration for home to remote direction.  |
| remote-to-home |
                                 Specifies the IPv4 unicast redistribution configuration for remote to home direction.  |
| route-map WORD<1-64> |
                                 Specifies the name of the route policy.  |
| vrf WORD<1-16> |
                                 Specifies the unicast redistribution configuration for specific VRF instance.  |
