View Imported Routes
Display information about BGP imported routes.
The following table defines parameters for the show ip bgp imported-routes command.
 Variable  |
 Value  |
 longer-prefixes  |
 Shows long prefixes. The longer-prefixes indicate the mask length from a specified prefix to 32 (for example, show from prefix a.b.c.d/len to a.b.c./32).  |
 <prefix/len>  |
 Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32).  |
 vrf WORD<1–16>  |
 Specifies a VRF instance by name (the string length ranges from 1–16 characters).  |
 vrfids WORD<0–512>  |
 Specifies a range of VRFs by ID number (the ID ranges from 0–512).  |
